樓主 |
發表於 2005年1月6日 08:07 AM
顯示全部樓層
MULTIPLEX模型技術部回函翻譯:
行動電話是個發射機且會造成干擾在現在是一般常識,因此在飛機、醫院及其他地方是禁止使用。因為行動電話會依至基地台的距離來改變發射功\率,有可能相較於遙控發射
機十倍以上的輸出,因而造成嚴重短距離干擾,這是依照不同情況而改變,任何廠牌的任何發射機皆可能會但不一定會發生。這是有技術上的檢查標準來獲得正式認證,我門
的發射機都超過這標準。但唯一真正解決的方法是遠離任何行動電話至少2公尺遠,當一個飛行員,注意安全是你的責任,所以你要要求周圍的人要關機或遠離,你有做我們建議的距離檢查嗎?因該會發現這問題。
Reply-To: "Multiplex" <support@multiplexrc.de>
Date: Wed, 5 Jan 2005 09:03:16 +0100 (CET)
To: jinn.tsai
Dear Mr. Tsai,
today, its common sence, that mobiles are transmitters and can cause
interferences. Due to this, its forbidden to use it in airplanes, hospitals
and on other places.
Due the mobile-phone variies its output in relation to the distance to the
next transponder, there might be a relation 10+/ 1 output mobile /
rc-transmitter, which may result into several short
distance-interferences.This variies from case to case and can but must not
happen with any RC-transmitter, any brand.
There are technical checkpoints for this, to get the official approval,
which all our TX's more than fullfill.
But the only real solution is to keep a distance of minimum 2 m from any
mobile-phone. As a pilot, its your duty to take care on the safety, so you
should ask the people arround you, either to switch off their mobiles or to
stay away.
Did you make a range check with the same constellation, as its recommended
too? This should have shown the problem.
Best regards
MULTIPLEX Modelltechnik GmbH & Co. KG |
